7. Technical specifications
MultiPlus 230V | 48/15000/200-100 | ||
PowerControl / PowerAssist | Yes | ||
AC input | Input voltage range: 187 - 270 VAC, Input frequency: 50 - 60Hz Cos φ >0.8 | ||
Maximum feed through current | 100A | ||
INVERTER | |||
Input voltage range | 38 – 66V | ||
Output in inverter mode (1) | Output voltage: 230 VAC ± 2% Frequency: 50 Hz ± 0,1% | ||
Continuous output power at 25°C / 77°F (3) | 15000VA | ||
Continuous output power at 25°C / 77°F | 12000W | ||
Continuous output power at 40°C / 104°F | 10000W | ||
Continuous output power at 65°C / 150°F | 7000W | ||
Maximum feed-in power | 15000VA | ||
Peak power | 27000W | ||
DC Input current | 350A | ||
Maximum continuous AC output current | 53A | ||
Power factor range | ±0.8 | ||
Maximum AC output fault current (1 second) | 150A | ||
Maximum efficiency | 96% | ||
Zero-load power | 55W | ||
Zero-load power in AES mode | 39W | ||
Zero-load power in Search mode | 6W | ||
CHARGER | |||
AC input | Voltage range: 187 - 270VAC Frequency: 45 - 65Hz Power factor: 1 | ||
Charge voltage 'absorption' | 57.6V | ||
Charge voltage 'float' | 55.2V | ||
Storage mode | 52.8V | ||
Charge current house battery (4) | 200A | ||
GENERAL | |||
Auxiliary output | Yes (50A) | ||
External AC current sensor (optional) | 100A | ||
Programmable relay (5) | Yes | ||
Protection (2) | a - g | ||
VE.Bus communication port | Three-phase operation, remote monitoring and system integration | ||
General purpose com. port | Yes, 2x | ||
Operating temperature | -20 to 65°C (-4 to 50°F) | ||
Cooling | Fan assisted | ||
Maximum humidity (non-condensing) | 95% | ||
Maximum altitude | 3500m | ||
ENCLOSURE | |||
Material & Colour | Alluminium, blue RAL 5012 | ||
Protection category | IP 20 | ||
Battery-connection | Four M8 bolts (2 positive and 2 negative connections) | ||
230VAC connections | Bolts M6 | ||
Weight | 70 kg | ||
Dimensions h x w x d | 571 x 423 x 334 mm | ||
STANDARDS | |||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN-IEC 62109-1, EN-IEC 62109-2 | ||
Emission / Immunity | EN 55014-1, EN 55014-2 EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | ||
Uninterruptible power supply | Please consult the certificates on our website. | ||
Anti-islanding | Please consult the certificates on our website. | ||
