8. Technical Data
MultiPlus 12/2000/80 MultiPlus 24/2000/50 MultiPlus 48/2000/25 | ||||
PowerControl / PowerAssist | Yes | |||
Transfer switch | 32A | |||
INVERTER | ||||
Input voltage range |
Output |
Cont. output power at 25°C (3) | 2000VA | |||
Cont. output power at 25°C | 1600W | |||
Cont. output power at 40°C | 1400W | |||
Cont. output power at 65°C | 1000W | |||
Peak power | 3500W | |||
Maximum efficiency in % | 93 / 94 / 95 | |||
Zero-load power | 10 / 11 / 11W | |||
Zero-load power search mode | 3 / 4 / 4W | |||
CHARGER | ||||
AC Input | Input voltage range: 187-265 VAC Input frequency: 45 – 65 Hz | |||
Charge voltage 'absorption' | 14,4 / 28,8 / 57,6V | |||
Charge voltage 'float' | 13,8 / 27,6 / 55,2V | |||
Storage mode | 13,2 / 26,4 /52,8V | |||
Charge current house battery (4) | 80 / 50 / 25A | |||
Charge current starter battery | 1 A (12V and 24V models only) | |||
Battery temperature sensor | Yes | |||
GENERAL | ||||
Programmable relay (5) | Yes | |||
Protection (2) | a – g | |||
Common Characteristics | Operating temp. range: -40 to +65°C (fan assisted cooling) Humidity (non-condensing): max 95% | |||
ENCLOSURE | ||||
Common Characteristics | Material & Colour: Steel/ABS (blue RAL 5012) Protection category: IP 21 | |||
Battery-connection | M8 bolts | |||
230V AC-connection | Screw terminals 13 mm² (6 AWG) | |||
Weight | 15,5kg | |||
Dimensions (h x w x d) | 506 x 236 x 147 mm | |||
STANDARDS | ||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN 62109-1 | |||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | |||
Road vehicles | ECE R10-4 | |||
