3. Safety instructions
Important
SAVE THESE INSTRUCTIONS – This manual contains important instructions that shall be followed during installation and maintenance.
Warning
Danger of explosion from sparking
Danger of electric shock
Please read this manual carefully before the product is installed and put into use
Install the product in a heatproof environment. Ensure therefore that there are no chemicals, plastic parts, curtains or other textiles, etc. in the immediate vicinity of the equipment.
It is normal for the Orion Smart DC-DC charger to get hot during operation, keep any objects that are heat-sensitive away
Ensure that the equipment is used under the correct operating conditions. Never operate it in a wet environment.
Never use the product at sites where gas or dust explosions could occur
Always provide proper ventilation during charging
Avoid covering the charger
Refer to the specifications provided by the manufacturer of the battery to ensure that the battery is suitable for use with this product. The battery manufacturer's safety instructions should always be observed
In addition to this manual, the system operation or service manual must include a battery maintenance manual applicable to the type of batteries used.
Never place the charger on top of the battery when charging
Prevent sparks close to the battery. A battery being charged could emit explosive gasses.
This device is not to be used by persons (including children) with reduced physical, sensory or mental capabilities, or lack of experience and knowledge, unless they have been given supervision or instruction.
Use flexible multistranded copper cable for the connections. The maximum diameter of the individual strands is 0,4mm/0,125mm² (0.016 inch/AWG26).
The installation must include a fuse in accordance with the recommendations in the table ”CABLE AND FUSE RECOMMENDATIONS”
