6. Technical specifications
Smart IP43 Charger | 12/30 (1+1) & (3) | 12/50 (1+1) & (3) | 24/16 (1+1) & (3) | 24/25 (1+1) & (3) | ||
Input Voltage | 85 - 265VAC (full power from 100VAC, startup from 90VAC) | |||||
DC Input voltage range | 290 – 375 VDC | |||||
Frequency | 45-65 Hz | |||||
Power factor | 1 | |||||
Back current drain |
No load power consumption | 1 W | |||||
Maximum Efficiency | 12/30: 94% | 12/50: 92% | 94% | 94% | ||
Charge voltage - Absorption / Float / Storage' | Normal: 14.4V / 13.8V / 13.2V High: 14.7V / 13.8V / 13.2V Li-ion: 14.2V / N/A / 13.5V | Normal: 28.8V / 27.6V / 26.4V High: 29.4V / 27.6V / 26.4V Li-ion: 28.4V / N/A / 27.0V | ||||
Fully programmable | Yes, with Bluetooth and/or VE.Direct | |||||
Maximum input current setting | 3 – 10A | |||||
Charge current house battery | 30 A | 50 A | 16 A | 25 A | ||
Low current mode | 15 A | 25 A | 8 A | 12.5 A | ||
Temperature compensation - Default | -16mV/°C | -32mV/°C | ||||
Charge current starter battery | 4 A Max (1+1 output models only) | |||||
Charge algorithm | 6-stage adaptive (3 stage for Li-ion) | |||||
Battery capacity | 150-300 Ah | 250-500 Ah | 80-160 Ah | 125-250 Ah | ||
Number of battery connections | 2 | 3 | 2 | 3 | ||
Protection | Battery reverse polarity (fuse, not user accessible) / Output short circuit / Over temperature | |||||
Can be used as power supply | Yes, output voltage can be set with Bluetooth and/or VE.Direct | |||||
Operating temp. range | -20 to 60°C (0 - 140°F) Rated output current up to 40°C, derate linearly to 20% at 60°C | |||||
Humidity (non-condensing) | max 95% | |||||
Remote on/off | Yes (2 pole terminal) | |||||
Relay (programmable) | Yes (SPDT - 5A up to 250VAC / 5A up to 28VDC) | |||||
Bluetooth | Power: -4dBm | Frequency: 2402 - 2480MHz | |||||
ENCLOSURE | ||||||
Material & Color | Aluminium (blue RAL 5012) | |||||
Battery-connection | Screw terminals 16 mm² (AWG6) | |||||
AC-connection | IEC 320 C14 inlet with retainer clip (AC cord with country specific plug must be ordered separately) | |||||
Protection category | IP43 (electronic components), IP22 (connection area) | |||||
Weight kg (lbs) | 2,7 kg (6 lbs) | |||||
Dimensions (hxwxd) | 180 x 249 x 116 mm (7.1 x 9.8 x 4.6 inch) | |||||
STANDARDS | ||||||
Safety | EN 60335-1, EN 60335-2-29 | |||||
Emission | EN 55014-1, EN 61000-6-3, EN 61000-3-2 | |||||
Immunity | EN 55014-2, EN 61000-6-1, EN 61000-6-2, EN 61000-3-3 | |||||
Vibration | IEC68-2-6:10-150Hz/1.0G |
