8. Technical Specifications
Quattro-II | 24/5000/120-50 | 48/5000/70-50 | ||||
PowerControl / PowerAssist | Yes | |||||
AC input | Input voltage range: 187-265 VAC Input frequency: 45 – 65 Hz | |||||
Maximum feed through current | 50 A | |||||
INVERTER | ||||||
Input voltage range | 19 – 33 V 38 – 66 V | |||||
Output (1) | Output voltage: 230 VAC ± 2% Frequency: 50 Hz ± 0,1% | |||||
Cont. output power at 25°C / 77°F (3) | 5000 VA | |||||
Cont. output power at 25°C / 77°F | 4000 W | |||||
Cont. output power at 40°C / 104°F | 3700 W | |||||
Cont. output power at 65°C / 150°F | 3000 W | |||||
Maximum feed-in power | 5000 VA | |||||
Peak power | 9000 W | |||||
Maximum efficiency | 96 % | |||||
Zero-load power | 18 W | |||||
Zero-load power in AES mode | 12 W | |||||
Zero-load power in Search mode | 2 W | |||||
CHARGER | ||||||
AC input | Input voltage range: 187-265 VAC Input frequency: 45 – 65 Hz Power factor: 1 | |||||
Charge voltage 'absorption' | 28,8 / 57,6 V | |||||
Charge voltage 'float' | 27,6 / 55,2 V | |||||
Storage mode | 26,4 / 52,8 V | |||||
Charge current house battery (4) | 120 A | 70 A | ||||
GENERAL | ||||||
Auxiliary output | Yes (32 A) Default setting: switches off when in inverter mode | |||||
Programmable relay (5) | Yes | |||||
Protection (2) | a - g | |||||
VE.Bus communication port | For parallel and three phase operation, remote monitoring and system integration | |||||
General purpose com. port | Yes, 2x | |||||
Common Characteristics | Operating temp.: -40 to +65°C (-40 – 150°F) (fan assisted cooling) Humidity (non-condensing): max 95% Maximum Altitude 2000m | |||||
ENCLOSURE | ||||||
Material & Colour | Steel, blue RAL 5012 Protection category: IP21 Pollution degree 2, OVC3 | |||||
Battery-connection | M8 bolts | |||||
230 VAC-connections | Screw terminals 13 mm² (6 AWG) | |||||
Weight | 31 kg | 29 kg | ||||
Dimensions (hxwxd) | 607 x 329 x 149 mm | 565 x 320 x 148 mm | ||||
STANDARDS | ||||||
Safety | EN 60335-1, EN 60335-2-29, IEC62109-1, IEC62109-2 | |||||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, EN 61000-6-2, EN 61000-6-3 | |||||
Uninterruptible power supply | Please consult the certificates on our website. | |||||
Anti-islanding | Please consult the certificates on our website. | |||||
