Smart BMS CL 12-100 | |
Alternator port - max charge current | 100A (with a 125A fuse) |
Input voltage to start charging | >13A |
Current consumption, remote on | 16mA (excluding Load output and Charge output current) |
Current consumption, remote off | 5mA (BMS functionality still active) |
Load disconnect output | Normally high (Vbat – 0.1V) Source current limit: 10mA (short circuit protected) Sink current: 0A (output free floating) |
Charge disconnect output | Normally high (Vbat – 0.1V) Source current limit: 10mA (short circuit protected) Sink current: 0A (output free floating) |
Pre-alarm output | Normally free floating High (Vbat) in case of alarm, max. 1A (not short circuit proof) |
System on/off: Remote L and Remote H | Use modes:
GENERAL | |
Operating temperature range | -40°C to +60°C |
Humidity, maximum / average | 100% / 95% |
Protection, electronics | IP65 |
DC power connection | M8 |
Mounting torque | 10Nm |
DC connector battery minus | Faston female, 6.3mm |
ENCLOSURE | |
Weight | 1.6 kg |
Dimensions (hxwxd) | 65 x 120 x 224 mm |
STANDARDS | |
Emission | EN 61000-6-3, EN 55014-1 |
Immunity | EN 61000-6-2, EN 61000-6-1, EN 55014-2 |
Automotive Directive | ECE R10-5 |
