The battery and BMS are monitored and controlled using the VictronConnect app.
VictronConnect has three pages for this purpose: a status page, a battery page and a history page. The individual parameters are explained below.
Status page: The status page provides information about the current battery and BMS status.
Battery page: The battery page provides information about the installed battery bank and gives more detailed information about each individual battery. Battery bank info
History page: The history page shows information about the battery over time since installation or since the history was last reset.
VictronConnect can display key smallBMS NG data directly on the Device List page—without needing to connect to the product. This includes visual notifications for warnings, alarms, and errors, allowing quick diagnostics at a glance.
Available parameters:
For details on enabling Instant Readout, refer to the VictronConnect manual, available on the VictronConnect download page.
The smallBMS NG can be reset to factory settings via the VictronConnect app.
How to reset:
Open VictronConnect
Tap the cogwheel icon to access Settings.
Tap the three vertical dots in the Settings menu.
Select Reset to defaults, then confirm with Yes.
The following settings will be restored to their default values:
The BMS is equipped with two LEDs: the Bluetooth Status LED and the Error LED. These indicate the current operating state as well as any faults.
The following tables list all LED, warning, alarm and error codes:
Bluetooth Status LED | Description |
Off | No system power or Bluetooth is disabled in the VictronConnect app. |
Blue on | A Bluetooth device is connected. |
Blue blinking | Bluetooth is active but no device is connected. |
Error LED | Description |
Off | No warning/alarm/error active. |
Red blinking | A warning is active. |
Red on | A alarm and/or error is active. |
Warning codes
VictronConnect warning code | Message | Instructions / Remarks |
W-B01 | Low cell voltage | Charge the battery or reduce the load to prevent an imminent system shutdown. |
W-B05 | Communication with battery lost | Check the cables between BMS and Battery. |
W-B07 | Low SoC | Charge battery or reduce load to prevent imminent system shutdown. |
Alarm codes
VictronConnect alarm code | Message | Instructions / Remarks |
A-B01 | Low cell voltage | Charge battery. The system will turn the loads back on when the battery is sufficiently charged. |
A-B05 | Communication with battery lost | Check the cables between BMS and Battery. |
A-B07 | Low SoC | Charge battery. The system will turn the loads back on when the battery is sufficiently charged. |
A-B08 | Low bank voltage | Charge battery. The system will turn the loads back on when the battery is sufficiently charged. |
A-B09 | High battery temperature | The battery temperature is too high for charging. Try to reduce the ambient temperature. |
Error codes
VictronConnect error code | Message | Instructions / Remarks |
E-B01 | Battery configuration invalid | Check VictronConnect ´Battery´ tab for more details. Check if batteries BMS cables are all connected |
E-B05 | Battery configuration invalid | Check VictronConnect ´Battery´ tab for more details. Check if batteries BMS cables are all connected. |
E-B09 | Battery voltage not allowed | The battery voltage is too high or too low. Check the battery voltage and check the battery settings in the VictronConnect app. This error occurs when the battery voltage is outside all system voltage ranges (9V > Vbat > 60V) |
E-B11 | Hardware error | Contact your Victron dealer. |
