smallBMS with pre-alarm
4. Specifications
Operating voltage (Vbat)
8 - 70Vdc
Power supply cable and fuse (not supplied)
Recommended fuse size 0.3A - 2.5A, dependent on devices connected to Load disconnect and pre-alarm output
Current consumption, remote on
2.2mA (excluding Load and Charge disconnect output current)
Current consumption, low cell voltage
1.2mA
Current consumption, remote off
1.2mA
Load disconnect output
Normally high (Vbat – 0.1V)
Source current limit: 1A (not short circuit protected)
Sink current: 0A (output free floating)
Source current limit: 10mA (short circuit protected)
Pre-alarm output
Normally free floating (low)
In case of alarm: output voltage Vbat -0.1V
Max output current: 1A (not short circuit protected)
Remote on/off:
Remote L and Remote H
Use modes:
  1. ON when the L and H terminal are interconnected
  2. ON when the L terminal is pulled to battery minus (V < 3.5V)
  3. ON when the H terminal is high (2.9V < VH < Vbat)
  4. OFF in all other conditions
GENERAL
Operating temperature range
-20°C to +50°C (0 - 120°F)
Humidity
Max 95% (non-condensing)
Protection, electronics
IP20
ENCLOSURE
Weight
0.1kg
Dimensions (hxwxd)
106 x 42 x 23 mm
Material and colour
ABS, matt black
STANDARDS
Safety
EN 60950
Emission
EN 61000-6-3, EN 55014-1
Immunity
EN 61000-6-2, EN 61000-6-1, EN 55014-2
Automotive Directive
Regulation UN/ECE-R10 Rev.4
