Field test: PV Modules
Total solar yield: --
S
S
S
S
W
Romania
Installation date: 09-03-2020
Irradiance
Mono: 9158 kWh
Split-cell: 9511 kWh
Poly: 9113 kWh
Perc: 9471 kWh
Perc-east: 1970 kWh
Perc-west: 1730 kWh
BlueSolar PWM-LCD&USB
  • Liquid Crystal Display
  • Two 5 Volt USB outputs
  • Lighting control function, fully programmable
  • Three stage battery charging (bulk, absorption, float), fully programmable
  • Load output with low voltage and manual disconnect (programmable)
  • Load output protected against over load and short circuit
  • Protected against reverse polarity connection of the solar panels and/or battery
BlueSolar PWM DUO-LCD&USB
All the above-mentioned functions, plus:
  • Charges two separate batteries
  • Programmable charge current ratio
  • External Temperature sensor
Models: 12 / 24 / 48 Volt
Downloads & Support
Find a dealer
