1. Safety precautions
1.1. General safety precautions
Notice
Read this manual carefully. It contains important instructions that must be followed during installation, operation and maintenance.
Save these instructions for future reference on operation and maintenance.
1.2. High voltage safety warnings
Danger
Voltages above 50Vdc up to 120Vdc (ELV) are dangerous and will cause serious injury, death or equipment damage. Use appropriate personal protection equipment. De-energize the system before maintenance and use appropriate insulated tools.
Voltages above 120Vdc (LV) are very dangerous and will cause serious injury, death or equipment damage. Use appropriate personal protection equipment. De-energize before maintenance and use appropriate insulated tools.
1.3. Battery safety warnings
Warning
Working in the vicinity of a lead acid battery is dangerous. Batteries can generate explosive gases during operation. Never smoke or allow a spark or flame in the vicinity of a battery. Provide sufficient ventilation around the battery.
Wear eye and clothing protection. Avoid touching eyes while working near batteries. Wash your hands when done.
If battery acid contacts skin or clothing, wash them immediately with soap and water. If acid enters an eye, immediately flood the eye with running cold water for at least 15 minutes and get medical attention immediately.
Be careful when using metal tools in the vicinity of batteries. Dropping a metal tool onto a battery might cause a short circuit and possibly an explosion.
Remove personal metal items such as rings, bracelets, necklaces, and watches when working with a battery. A battery can produce a short circuit current high enough to melt objects such as rings, causing severe burns.
1.4. Transport and storage
Notice
Store this product in a dry environment.
Store this product in temperatures between -40°C and +60°C.
