Blue Smart IP65 Charger | 12V 4 / 5 / 7 / 10 / 15 / 25A | 24V 5 / 8 / 13A |
Input voltage and frequency range | 180 - 265VAC | 45 - 65Hz | |
Efficiency | 94% | 95% |
Standby power consumption | 0.5W | |
Charge voltage - Absorption | Normal: 14.4V High: 14.7V Li-ion: 14.2V | Normal: 28.8V High: 29.4V Li-ion: 28,4V |
Charge voltage - Float | Normal: 13.8V High: 13.8V Li-ion: 13.5V | Normal: 27.6V High: 27.6V Li-ion: 27.0V |
Charge voltage - Storage | Normal: 13.2V High: 13.2V Li-ion: 13.5V | Normal: 26.4V High: 26.4V Li-ion: 27.0V |
Max output current - Normal mode | 4 / 5 / 7 / 10 / 15 / 25A | 5 / 8 / 13A |
Max output current - Low current mode | 2 / 2 / 2 / 3 / 4 / 10A | 2 / 3 / 4A |
Max battery capacity (recommended) | 40 / 50 / 70 / 100 / 150 / 250Ah | 50 / 80 / 130Ah |
Min battery capacity - Normal mode | Lead-acid: 13 / 17 / 23 / 33 / 50 / 83Ah Lithium: 8 / 10 / 14 / 20 / 30 / 50Ah | Lead-acid: 17 / 27 / 43Ah Lithium: 10 / 16 / 26Ah |
Min battery capacity - Low current mode | Lead-acid: 7 / 7 / 7 / 10 / 13 / 33Ah Lithium: 4 / 4 / 4 / 6 / 8 / 20Ah | Lead-acid: 7 / 10 / 13Ah Lithium: 4 / 6 / 8Ah |
Temperature compensation (lead-acid only) | 16mV/°C | 32mV/°C |
Charge algorithm | 7-stage adaptive | |
Power supply mode | Yes | |
Back current drain | 0.7Ah/month (1mA) | |
Protection | Reverse polarity, output short circuit, over temperature | |
Operating temperature | -40 to +50°C (full rated output up to 30°C) | |
Humidity (non condensing) | Max 95% | |
Enclosure | ||
Battery connection | 1.5 meter red and black cable | |
AC connection | 1.5m cable with CEE 7/17, CEE 7/16, BS 1363 or AS/NZS 3112 plug | |
Protection category | IP65 (splash and dust proof) | |
Weight | 12/25 & 24/13: 1.9kg | Other models: 0.9kg | |
Dimensions (h x w x d) | 12/4, 12/5: 45 x 81 x 182mm 12/7, 24/5: 47 x 95 x 190mm 12/10, 12/15, 24/8: 60 x 105 x 190mm 12/25, 24/13: 75 x 140 x 240mm | |
Standards | ||
Safety | EN 60335-1, EN 60335-2-29 | |
Emission | EN 55014-1, EN 61000-6-3, EN 61000-3-2 | |
Immunity | EN 55014-2, EN 61000-6-1, EN 61000-6-2, EN 61000-3-3 | |
Automotive | E4-10R |
