Isolation transformer
4. Operation
Warning
Check the input and output voltage configuration before operating the isolation transformer.
4.1. Automatic input voltage detection
The isolation transformer automatically detects the incoming voltage and will set its input voltage mode according to the below table.
Input voltage range
Green “on” LED
Yellow “115V" LED
Yellow “230V” LED
Behaviour
0 - 87V
On
Off
Off
Both the input and output are switched off.
88V - 130V
On
On
Off
Operating in 115V input mode.
130V - 185V
On
Off
Off
185V - 250V
On
Off
On
Operating in 230V input mode.
4.2. LED indications
The isolation transformer has the following LED indications:
LED
Colour
Description
on
Green
Lights when the isolation transformer is operational.
230V
Yellow
Lights when the isolation transformer is operating in 230Vac input mode.
115V
Yellow
Lights when the isolation transformer is operating in 115Vac input mode.
Temperature
Red
Lights when the fan is on.
4.3. Inrush current limiter
The inrush current limiter prevents upstream circuit breakers from tripping when switching on the isolation transformer.
4.4. Temperature protection
The isolation transformer is fan cooled. The fan speed is temperature-controlled. Its speed (rpm) will increase if the temperature increases.
The isolation transformer is protected against overtemperature and will switch off in case of overheating.
