In this section:
The inrush current limiter prevents upstream circuit breakers from tripping when switching on the isolation transformer.
The isolation transformer is fan cooled. The fan speed is temperature-controlled. Its speed (rpm) will increase if the temperature increases.
The isolation transformer is protected against overtemperature and will switch off in case of overheating.
