Isolation Transformer
5. Technical specifications
7000 Watt
AC input voltage
230V
AC output voltage
240V
Frequency
50/60Hz
Output current rating
32A
Soft start
Yes
Operating temperature range
-20°C to 40°C
Humidity
Max 95%, non-condensing
Transformer type
Toroidal (low noise, low weight), 1:1.05 ratio
Enclosure
Aluminium (blue RAL5012)
Protection category
IP21
Safety
EN 60076
Weight
30.7kg
Dimensions (h x w x d), mm
362 x 258 x 218
