6. Installation
6.1. Mechanical connections
6.1.1. Lynx module connection features
The Lynx module can be opened up by unscrewing the 2 cover screws.
The contacts on the left side are covered by a removable rubber sleeve.
Red is the positive and black is the negative busbar.
Location of front cover screws and the removable sleeves
6.1.2. Mounting and interconnecting Lynx modules
This paragraph explains how to attach several Lynx modules to each other and how to mount the Lynx assembly into its final location.
For a mechanical drawing of the housing with dimensions and the location of the mounting holes, see the Enclosure Dimensions of this manual.
These are the points to take into consideration when interconnecting and mounting Lynx modules:
If Lynx modules are going to be connected to the right and if the Lynx module is fitted with a plastic barrier on the right side, remove the black plastic barrier. If the Lynx module is located as the most right module, leave the black plastic barrier in place.
If Lynx modules are going to be connected to the left, remove the red and black rubber sleeves. If the Lynx module is located as the most left module, leave the red and black rubber sleeves in place.
If the Lynx system contains a Lynx Smart BMS or Lynx Shunt VE.Can, the left side is the battery and the right side is the DC system side.
Place the washer, spring washer and nut on the bolts and tighten the bolts using a torque of:
M8 Model: 14Nm
Mount the Lynx assembly in its final location using the 5mm mounting holes.
Correct placement of the M8 (M10) washer, spring washer and nut.
6.2. Electrical connections
6.2.1. Connect DC wires
This chapter might not apply if the Lynx module is connected to other Lynx modules like this can be the case for the Lynx Smart BMS or the Lynx Shunt VE.Can.
For all DC connections, the following applies:
All cables and wires connected to the Lynx module need to have been fitted with M8 cable lugs.
Pay attention to the correct placement of the cable lug, washer, spring washer and nut on each bolt when attaching the cable to the bolt.
Tighten the nuts using a torque of:
M8 Model: 14Nm
Correct placement of the M8 Cable lug, washer, spring washer and nut
6.2.2. Connect RJ10 cable(s)
These instructions only apply if the system contains Lynx distributor(s) together with a Lynx Smart BMS or a Lynx Shunt VE.Can.
There are two RJ10 connectors in each Lynx Distributor, one on the left and one on the right. See the drawing below.
Locations of the RJ10 connectors and RJ10 cable recesses on the Lynx Distributor and the Lynx Shunt VE.Can
To connect the RJ10 cables between the various Lynx modules, do the following:
Plug one side of the RJ10 cable in the RJ10 connector of the Lynx Distributor with the retainer clip of the RJ10 connector facing away from you.
Feed the RJ10 cable through the recess at the bottom of the Lynx Distributor; see the above picture.
To connect to a Lynx Shunt VE.Can, feed the cable through its bottom recess and plug the RJ10 cable into the RJ10 connector.
Connection example Lynx Shunt VE.Can system - RJ10 cables indicated in yellow
6.2.3. Connect the temperature sensor
An optional battery temperature sensor can be connected to the green terminal with the + and - symbol.
The connector can be removed from the terminal, for easy connection.
The temperature sensor is polarity sensitive. Connect the black wire to the - terminal and the red wire to the + terminal.
Temperature sensor connection Lynx Shunt VE.Can
6.2.4. Connect the alarm relay
The alarm relay connector is the black 2-way connector. See below image for its location.
Alarm relay connection Lynx Shunt VE.Can
6.2.5. Place main fuse
Place the main fuse in the Lynx Shunt VE.can.
Be aware that if the positive bus is already powered, the moment the fuse is placed the system will become live.
Placing the CNN fuse in the Lynx Shunt VE.Can
6.2.6. Connect the GX device
Connect the Lynx Shunt VE.Can VE.Can port to the GX device VE.Can port using a RJ45 cable.
Multiple VE.Can devices can be interconnected, but make sure that the first and the last VE.Can device both have a VE.Can RJ45 terminator installed.
Power the GX device from the output of the Lynx Shunt VE.Can or a Lynx distributor connected to the output of the Lynx Shunt VE.Can.
Wiring example Lynx Shunt VE.Can and GX device
Location VE.Can connectors Lynx Shunt VE.Can
6.3. Configuration and settings
6.3.1. Settings Lynx Shunt VE.Can
Once powered up and connected to a GX device, navigate to the Lynx Shunt VE.Can settings menu on the GX device to make and change settings.
Most settings can be left to their default values, but there are a few essential settings to make by your own :
Set the battery capacity.
If lithium batteries are used, specific battery monitor settings are needed. Refer to the battery monitor settings chapter.
If the alarm relay is used, set the alarm relay parameters.
For a full overview and an explanation of all battery monitor settings, refer to the battery monitor setting chapter
Making Lynx Shunt VE.Can settings using a GX device
