12. Technical specifications Lynx Shunt VE.Can
In this section:
Power | |
Supply voltage range | 9 - 70 Vdc |
Supported system voltages | 12, 24 or 48V |
Reverse polarity protection | No |
Current rating | 1000Adc continuous |
Power consumption | 60mA @ 12V 33mA @ 24V 20mA @ 48V |
Potential free alarm contact | 3A, 30Vdc, 250Vac |
Connections | |
Busbar | M8 |
Fuse | M8 |
VE.Can | RJ45 and RJ45 terminator |
Power supply connection to Lynx Distributor | RJ10 (a RJ10 cable ships with each Lynx Distributor) |
Temperature sensor | Screw terminal |
Relay | Screw terminal |
Physical | |
Enclosure material | ABS |
Enclosure dimensions (hxwxd) | 190 x 180 x 80mm |
Unit weight | 1.4 kg |
Busbar material | Tinned copper |
Busbar dimensions (hxw) | 8 x 30mm |
Environmental | |
Operating temperature range | -40°C to +60° |
Storage temperature range | -40°C to +60° |
Humidity | Max. 95% (non-condensing) |
Protection class | IP22 |
