The LCD screen displays the following information:
A number reading.
The unit of the reading: V, A, W, kWh, h or !
The type of reading: load, battery, PV, min, max or charge stage.
Connection status indicator.
Full LCD readout
The digits used to represent letters and numbers
The connection status of the display is indicated by a "double arrow" symbol as indicated in below table.
Indicator | connection status |
| There is a connection between the display and the solar charger |
| There was a connection with the solar charger but the connection is lost. The last know values will be shown. |
| There has not been a connection with a solar charger. |
The buttons on the front of the display are used to navigate through the solar charger readings and are used when making solar controller and display settings.They have the following functions:
Button | Action |
Cancel or Back | |
Select or Confirm | |
Go to next or previous item or Increase or decrease value |
This menu shows the live solar charger readings. The MPPT Control display always starts up in this menu.
Press the up and down button cycle through all menu items.
These menu items will be displayed in order of appearance as indicated in below table:
LCD Display | Menu item | Description and notes |
PV power | Solar array output power. | |
PV voltage | Solar array voltage. | |
PV daily yield | The daily accumulative solar power received. | |
Battery error | Only visible in case there is an active error. | |
Battery charge stage | Charge stage: Bulk, Absorption, Float, Off or Fault. | |
Battery current | Battery charge current. | |
Battery voltage | Battery voltage. | |
Load output state | Load output switched on or off. Only visible on MPPTs with a load output. | |
Load current | The current into the load. Only visible on MPPTs with a load output. |
The history menu shows both the daily and overall solar charger history data. It shows items such as solar yield, battery voltages, time spend in each charge stage and past errors.
To enter and readout the history menu:
Press the SELECT button, while in the status menu.
Press the up or down button to navigate through the history items.
When arriving at the desired history item, press the SELECT button to see the value of that item.
If an item contains multiple values, press the SELECT button and then the up or down button to browse the various values within that item. For the daily items it is possible to scroll back to 30 days ago (data becomes available over time), a brief popup shows the day number.
To go back to the main history menu press the SETUP button.
To go back to the status menu press the SETUP button again.
History menu navigation chart
All available history menu items are listed in below table, in the order they appear when scrolling through the items.
LCD | Scrolling text | Description |
TOTAL YIELD | The cumulative PV yield since the last history reset. | |
MAX PANEL VOLTAGE | The maximum PV voltage since the last history reset. | |
MAX BATTERY VOLTAGE | The maximum battery voltage since the last history reset. | |
MIN BATTERY VOLTAGE | The minimum battery voltage since the last history reset. | |
LAST ERRORS | The last 4 errors since the last history reset. The number of blocks in the lower right of the LCD determines which error is currently shown, with 1 block being the latest and 4 blocks being the oldest. | |
YIELD | The daily PV yield, available for each day for the past 30 days. | |
MAX POWER | The daily maximum PV power, available for each day for the past 30 days. | |
MAX PANEL VOLTAGE | The daily maximum PV voltage, available for each day for the past 30 days. | |
MAX BATTERY CURRENT | The daily maximum battery current, available for each day for the past 30 days. | |
MAX BATTERY VOLTAGE | The daily maximum battery voltage, available for each day for the past 30 days. | |
MIN BATTERY VOLTAGE | The daily minimum battery voltage, available for each day for the past 30 days. | |
BULK TIME | The daily time spent in the bulk charge stage, available for each day for the past 30 days. | |
ABSORPTION TIME | The daily time spent in the bulk absorption stage, available for each day for the past 30 days. | |
FLOAT TIME | The daily time spent in the float stage, available for each day for the past 30 days. | |
LAST ERRORS | The last 4 daily errors. The number of blocks in the lower right of the LCD determines which error is currently shown, with 1 block being the latest and 4 blocks being the oldest. |
In the settings menu the the solar charger and MPPT Control settings can be viewed and changed.
Caution
Do not change settings unless you know what they are and what the effect of changing these setting can be. Incorrect settings may cause system problems including damage to batteries. When in doubt, seek advice from and experienced Victron Energy installer, dealer or distributor.
To navigate the settings menu:
Press the SETUP button for 2 seconds to enter the settings menu
The first menu item is shown.
Navigate to the desired menu item by pressing the up and down button.
Once arrived at the desired menu item, press the SELECT button to view the value the setting has been set to.
To modify this setting press the SELECT button again. teh value will now blink.
Press the up or down button to choose the desired value.
Press SELECT to confirm the change, you will hear a beep and will see the word SAVED. The change is made final.
Navigate to the next menu item, or press SETUP to return to the setup menu.
To leave the setting menu, press the SETUP button again.
It might be possible that the setup menu is locked, in which case the settings can only be viewed. When trying to change the setting the word LOCK is shown.
To unlock the settings menu:
Navigate to settings menu item 01 LOCK SETUP
Press the SETUP button, the setting ON is displayed
Press the SETUP button again
Press the down arrow button and select OFF
To leave the setting press the SETUP button.
When SELECT TO EDIT is ON, the current value is shown and a new value can immediately be selected.
When LOCK SETUP is ON, settings can only be changed after setting LOCK SETUP to off
MPPT Control setting navigation chart
All available settings are indicated in below table, in the order they appear when scrolling trough the menu, together with a basic description of each setting. For the full description of the solar charger settings refer to the solar charger manual.
Not all setting listed in below table might be available when connecting to certain models of solar chargers. The solar charger might not have the necessary hardware. For example, not all solar chargers are equipped with a load output.
Some settings might be missing from the settings menu. The MPPT Control display only allows to change the most common settings. More advance settings, like TX and RX port settings, are not accessible via the MPPT Control display. To configure these settings use the VictronConnect App or, for solar chargers 60A and up, use a SmartSolar Control display.
Number | Name | Setting |
01 | LOCK SETUP | When set to ON, none of the other settings can be changed. If an attempt is made to change a setting the word “LOCK” is shown together with the setting value. Set to OFF to unlock, so other settings can be changed. |
02 | BATTERY VOLTAGE | The system battery voltage; choose between a voltage setting or AUTO. When set to automatic (AUTO), an A will be shown in front of the voltage setting. |
03 | BATTERY TYPE | The charge algorithm for a specific battery type; set to FIXED or USER. When set to FIXED, the rotary switch on the solar charger determines the battery type. When set to USER, all charging related settings can be edited. As soon as any of the charging related settings are changed, this setting will automatically set to USER. |
04 | MAXIMUM CURRENT | The maximum charging current. |
05 | BULK TIME LIMIT | The maximum time the bulk charge stage is allowed to last. |
06 | ABSORPTION TIME LIMIT | The maximum time the absorption charge stage is allowed to last. |
07 | ABSORPTION VOLTAGE | The battery voltage at which the solar charger switches from bulk to absorption stage. |
08 | FLOAT VOLTAGE | The battery voltage at which the solar charger switches from absorption to float stage. |
09 | TEMP COMPENSATION | The temperature compensation coefficient in mV/°C for the whole battery bank (not per individual battery). |
10 | LOAD OUTPUT | The Load output operating mode. Possible values: OFF, AUTO (= BatteryLife), ALT1, ALT2, ON, USER1, USER2 |
11 | LOAD SWITCH HIGH | The high voltage level in case LOAD OUTPUT is set to USER1 or USER2 |
12 | LOAD SWITCH LOW | The low voltage level in case LOAD OUTPUT is set to USER1 or USER2 |
13 | CLEAR HISTORY | Clears the solar charger history |
14 | FACTORY DEFAULTS | Resets the solar charger settings back to factory defaults. |
15 | BACKLIGHT INTENSITY | Sets the back-light intensity of the MPPT Control LCD display. |
16 | BACKLIGHT ALWAYS ON | Determines whether the back-light of the MPPT Control LCD display is always on. |
17 | SCROLL SPEED | Determines the scroll speed of the MPPT Control. |
18 | SELECT TO EDIT | When set to OFF, the MPPT Control first shows the value of a setting and SELECT has to be pressed to be able to edit the value. |
19 | AUTO LOCK | When set to ON, the LOCK SETUP setting will be automatically set to ON 2 minutes after a setting has been changed. |
20 | SOFTWARE VERSION | The software (firmware) version of the MPPT Control. |
21 | SERIAL NUMBER | The serial number of the MPPT Control. |
22 | MPPT SOFTWARE VERSION | The software (firmware) version of the solar charger. |
23 | MPPT SERIAL | The serial number of the solar charger. |
24 | EQUALISATION VOLTAGE | Equalization voltage. |
25 | EQUALIZE | Initiates a manual equalization. |
