MPPT Control display manual
7. Specifications
Electrical
Supply voltage range when powered from battery
6.5 - 95Vdc
Supply voltage range when powered via VE.Direct cable
5Vdc
Power consumption with back-light turned off
< 0.05W
Operating temperature range
-20 - +50°C (0 - 120°C)
Power cable fuse rating
100mA
Mechanical
Installation type
Flush mount
Front diameter
63mm (2.5")
Front bezel
69 x 69mm (2.7x2.7")
Body diameter
52mm (2.0")
Body depth
31mm (1.2")
Power cable length
1.5m
Weight
50g
Suitability
Suitable for the entire Victron Energy BlueSolar MPPT and the SmartSolar MPPT solar charger range, with the exception of the (since long) discontinued BlueSolar MPPT 70/15.
