Filax 2
4. Installation
Physical installation:
  • Install the Filax in a dry and well-ventilated area.
  • Mount the Filax using the 4 holes at the base of the casing.
  • Open or close the casing by removing the 4 screws at the top of the casing lid.
Electrical installation
Caution
Electrical installation safety warnings:
  • Ensure that all AC powered sources are switched off or have been disconnected during the installation.
  • The AC inputs and AC output wiring must be protected by fuses or miniature circuit breakers (MCB) which are suitable for the applied wire cross section.
  • Ensure that both the priority and the alternate AC inputs are protected against current levels higher than 16A.
  • External earth leakage switches (RCD or RCCB) must be integrated in the Filax electrical system.
  • Connect the priority AC source to the PRIORITY: L, N and PE terminals.
  • Connect the alternate AC source to the ALTERNATE: L, N and PE terminals.
  • Ensure that both the priority and alternate AC inputs are protected against current levels higher than 16A.
  • Connect the AC load to the OUTPUT: L, N and PE terminals.
Filax_connections.svg
Electrical connections
Configuration
Wire links:
  • If the AC load is less than 850W, remove the LINK+HIGH POWER: L and N wire links.
  • If the AC load is more than 850W, keep the LINK+HIGH POWER: L and N wire links in place.
Remove both links if the load is less than 850W
Frequency jumper:
  • If the installation frequency is 50 Hz, remove the frequency jumper, or place it on only one of the pins (this is the default setting).
  • If the installation frequency is 60 Hz, place the jumper on both pins.
Filax_jumper_Hz.svg
Jumper placed = 60Hz
Jumper not placed = 50Hz
