Filax 2
8. Technical specifications
Electrical specifications
230V / 50Hz
240V / 60Hz
110V / 50Hz
120V / 60Hz
Maximum current
16A
Priority source: low voltage switching threshold
180Vac
88Vac
90Vac
Priority source: low voltage reverse switching threshold
188Vac
92Vac
94Vac
Priority source: low frequency switching threshold
45Hz
46Hz
45Hz
46Hz
Priority source: low frequency reverse switching threshold
47Hz
52Hz
47Hz
52Hz
Priority source: high frequency switching threshold
60Hz
68Hz
62Hz
68Hz
Priority source: high frequency reverse switching threshold
56Hz
63Hz
58Hz
63Hz
Priority source: maximum continuous input voltage
260Vac
130Vac
Alternate source: maximum continuous input voltage
260Vac
130Vac
Maximum load transfer time and reverse transfer time
16ms
Reverse switching delay (seconds)
30s
Operating temperature range
-20°C up to +50°C
Maximum (non-condensing) humidity
95%
Mechanical specifications
Material
ABS
Colour
RAL7035 (light grey)
Protection category
IP65
Dimensions
12 x 255 x 75mm (0.4 x 10 x 2.95 in)
Weight
0.8kg (28.2oz)
Standards
Safety
EN 60335-1, EN 60335-2-29
Emission and immunity
EN55014-1, EN 55014-2, EN 61000-3-3,EN 61000-6-3, EN 61000-6-2,EN 61000-6-1
