MultiPlus 12/2000/80 | MultiPlus 24/2000/50 | MultiPlus 48/2000/25 | |||
PowerControl / PowerAssist | Yes | ||||
Transfer switch | 32A | ||||
INVERTER | |||||
Input voltage range | 9.5 - 17Vdc | 19 - 33Vdc | 38 - 66Vdc | ||
Output voltage | 230Vac ± 2% | ||||
Output frequency(1) | 50Hz ± 0,1% | ||||
Cont. output power at 25°C (77°F) (3) | 2000VA | ||||
Cont. output power at 25°C (77°F) | 1600W | ||||
Cont. output power at 40°C (104°F) | 1400W | ||||
Cont. output power at 65°C (149°F) | 1000W | ||||
Peak power | 3500W | ||||
Maximum efficiency | 93% | 94% | 95% | ||
Zero-load power | 10W | 11W | 11W | ||
Zero-load power search mode | 3W | 4W | 4W | ||
CHARGER | |||||
AC Input voltage range | 187 - 265Vac | ||||
AC input frequency range | 45 - 65Hz | ||||
Charge voltage 'absorption' | 14.4V | 28.8V | 57.6V | ||
Charge voltage 'float' | 13.8V | 27.6V | 55.2V | ||
Storage mode | 13.2V | 26.4V | 52.8V | ||
Charge current house battery (4) | 80A | 50A | 25A | ||
Charge current starter battery | 1A | 1A | n/a | ||
Battery temperature sensor | Yes | ||||
GENERAL | |||||
Programmable relay (5) | Yes | ||||
Protection (2) | a – g | ||||
Operating temperature | -40 to +65°C (-40 to + 140°F), fan assisted cooling | ||||
Humidity | Maximum 95%, non-condensing | ||||
Maximum altitude | 2000m | ||||
ENCLOSURE | |||||
Material & colour: | Steel/ABS, blue RAL 5012 | ||||
Protection category: | IP 21 | ||||
Battery-connection | M8 bolts | ||||
230V AC-connection | Screw terminals 13 mm² (6 AWG) | ||||
Weight | 15.5kg (34.2lb) | ||||
Dimensions (h x w x d) | 506 x 236 x 147mm (19.92 x 9.29 x 5.79 inch) | ||||
STANDARDS | |||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN 62109-1 | ||||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | ||||
Road vehicles | ECE R10-4 | ||||
