In this section:
Smart BatteryProtect | SBP 48V 100A |
Max. continuous load current | 100A |
Peak current | 250A |
Operating voltage range | 24 - 70 V |
Current consumption | BLE On and when on: 1.9mA When off or low voltage shutdown: 1.7mA |
BLE Off and when on: 1.7mA When off or low voltage shutdown: 1.6mA | |
Alarm output delay | 12 seconds |
Max. load on alarm output | 50mA - short circuit proof |
Load disconnect delay | 90 seconds (immidiate if triggered by a BMS) |
Load reconnect delay | 30 seconds |
Default thresholds | Disengage: 42 V Engage: 48 V |
Operating temperature range | Full load: -40 °C to +40 °C (up to 60% of nominal load at 50 °C) |
Connection | M8 |
Mounting Torque | 9 Nm |
Weight | 0.8 kg 1.8 lbs |
Dimensions (hxwxd) | 62 x 123 x 120 mm |
2.5 x 4.9 x 4.8 inch |
