SUN Inverter Manual
6. Technical specifications
In this section:
6.1. Technical specifications SUN Inverter
SUN Inverter
12/250
24/250
INVERTER
Continuous power at 25°C (1)
250 VA
200 W
Continuous power at 40°C
175 W
Peak power
400 W
Output AC voltage
230 Vac +/- 3 %
Output AC frequency (adjustable)
50 Hz or 60 Hz +/- 0,1 %
DC Input voltage range
9.2 - 17 Vdc
18.4 - 34.0 Vdc
Low battery voltage shut down (adjustable)
9.3 Vdc
18.6 Vdc
Low battery voltage restart & alarm (adjustable)
10.9 Vdc
21.8 Vdc
Battery charged detect voltage (adjustable)
14.0 Vdc
28.0 Vdc
Maximum efficiency
87 %
88 %
Zero load power
4.2 W
5.2 W
Default zero load power in ECO mode (default search interval: 2.5 s, adjustable)
0.8 W
1.3 W
ECO mode stop and start power setting
Adjustable via the VictronConnect app
SOLAR CHARGER
Technology
Pulse Width Modulation (PWM)
Maximum PV array voltage
25 Vdc
50 Vdc
Maximum PV array current
15 A
10 A
Maximum PV array power
375 W
500 W
Solar panel type
36 cell solar panel
72 cell solar panel or two 36 cell solar panels in series
PV array voltage to initiate battery charging
Voltage that is higher than the battery voltage
Charge voltages
Temperature compensated charging
Yes, via an optional temperature sensor
GENERAL
Protection (2)
a – f
Operating temperature range
-40 to +60 °C (fan assisted cooling)
(derate 1.25 % per °C above 40 °C)
Humidity (non condensing)
max 95 %
Bluetooth wireless communication
For remote monitoring and system integration
VE.Direct communication port
ENCLOSURE
Material Colour
Steel chassis and plastic cover (blue Ral 5012)
Battery connection terminals
Screw terminals
Maximum battery cable cross section
10 mm² or AWG 8
PV connection terminals
Screw terminals
Maximum PV cable cross section
4 mm2 or AWG 12
Standard AC outlets
IEC-320 (male plug included)
Protection category
IP 21
Weight
2.4 kg / 5.3 lbs
Dimensions (hxwxd, mm)
Dimensions (hxwxd, inch)
86 x 165 x 260 mm
3.4 x 6.5 x 10.2 inch
ACCESSORIES
Remote on/off terminal
Yes, can be used for remotely turning unit on/off, or for battery temperature sensing.
Battery temperature sensor
Use Temperature sensor QUA PMP GX Device or a Smart Battery Sense.
Automatic AC transfer switch
Not built-in. Add a Filax2 transfer switch, or use an inverter/charger instead.
STANDARDS
Safety
EN/IEC 60335-1 / EN/IEC 62109-1
EMC
EN 55014-1 / EN 55014-2
IEC 61000-6-1 / IEC 61000-6-3
Automotive Directive
ECE R10-4 EN 50498
  1. Nonlinear load, crest factor 3:1
  2. Protection key:
    1. Output short circuit
    2. Overload
    3. Battery voltage too high
    4. Battery voltage too low
    5. Temperature too high
    6. DC ripple too high
