Connect the dongle directly to the VE.Direct port of a compatible Victron product.
Ensure that the compatible Victron product has been powered up so that the dongle is also powered.
On power-up, the blue LED will blink, and the red LED will quickly flash. The red LED will give a short flash to confirm that the red LED is functional.
Connect to the dongle using the VictronConnect app.
If a firmware update is required, the blue and red LED will blink fast in an alternating fashion. The VictronConnect app will automatically update the firmware.
If a firmware update is not required, the blue LED will slowly blink and the red LED is off
Once the VictronConnect App has established a successfully connection with the dongle (and the firmware was successfully updated), the blue LED will be on and the red LED will be off.
Quite often, the firmware of the connected Victron product will also be updated on first connection.
Notice
It is not possible to extend the 1.5m VE.Direct cable.
Connection drawing VE.Direct Bluetooth Smart Dongle
