2. Solar lighting function
The cable can be used in lighting applications in solar energy systems where energy consumption can be substantially reduced by dimming lights when appropriate. The resulting lower energy consumption will reduce the overall system costs and will increase light availability, even when the battery has only been partly charged due to bad weather. The cable connects the solar charger VE.Direct Tx pin to the PWM light-dimming terminal of a LED driver. | |||||||||||||||
Connection sequence:
| ![]() Wiring example - Controlling a streetlight LED driver. | ||||||||||||||
Configuration items in the solar charger settings in the VictronConnect app:
The PWM dimming function has been tested to work with the following LED drivers:
