3. Virtual load output function
The cable can be used to add load output functionality to the larger solar chargers, MPPT 100/30 and up, as these solar chargers do not have a load output like the smaller solar chargers. The cable connects the solar charger VE.Direct Tx pin to the Battery Protect remote H terminal. | |||||||||||||||
Connection sequence:
| ![]() Wiring example - Creating a Virtual load output using a BatteryProtect. | ||||||||||||||
Configuration items in the solar charger settings in the VictronConnect app:
Alternatively, a solid-state relay can be used instead of a BatteryProtect:
