Battery Switch - manual
Technical specifications
Rating
Continuous DC current rating*
275A
5 minute DC current rating
455A
Peak DC current (cranking) rating
1250A (10 sec)
Maximum DC operating voltage
60V
Terminal material
Tin-plated copper
Hex nut material
Tin-plated copper
Terminals
M10 (3/8 inch / 9.53mm)
Recommended torque
70 lbf·inch (8N.m)
Base material
Glass fiber reinforced nylon
Weight
0.4lb (0.2kg)
Dimensions (l x w x h)
2.71 x 2.71 x 2.87 inch (69 x 69 x 73 mm)
Ignition protection
ISO8846 / SAE J1171
* The battery switch is suitable to switch under load. But if alternators, motors or sensitive DC loads are connected, first switch these off before switching the DC supply off.
