MPPT solar charger manual
9. Technical specifications
9.1. Specifications 150/35 and 150/45
MPPT 150/35
MPPT 150/45
Battery voltage
12V / 24V / 48V Auto select, 36V: Manual select
Maximum battery current
35A
45A
Nominal PV power, 12V  1a,b
500W
650W
Nominal PV power, 24V 1a,b
1000W
1300W
Nominal PV power, 36V 1a,b
1500W
1950W
Nominal PV power, 48V  1a,b
2000W
2600W
Max. PV short circuit current   2
35A
45A
Maximum PV open circuit voltage
150V
Peak efficiency
98%
Self-consumption
12V: 20mA / 24V: 15mA / 48V: 10mA
Charge voltage 'absorption'
Default setting: 14.4V / 28.V / 43.2V 57.6V (adjustable)
Charge voltage 'float'
Default setting: 13,8V / 27,6V 14.4V / 55,2V (adjustable)
Charge voltage ‘equalization’ 3)
Default setting: 16.2V / 32.4V / 48.6V / 64.8V (adjustable)
Charge algorithm
Multi-stage adaptive (eight pre-programmed algorithms) or user defined algorithm
Temperature compensation
-16mV/°C / -32mV/°C / -64mV/°C
Protection
PV reverse polarity, output short circuit, over-temperature
Operating temperature
-30°C to +60°C (full rated output up to 40°C)
Humidity
95%, non-condensing
Maximum altitude
5000m (full rated output up to 2000m)
Environmental condition
Indoor type 1, unconditioned
Pollution degree
PD2
Data communication
VE.Direct 4
ENCLOSURE
Colour
Blue (RAL 5012)
Power terminals
16mm² / AWG6
Protection category
IP43 (electronic components), IP22 (connection area)
Weight
1.25kg
Dimensions  h x w x d
130 x 186 x 70 mm
STANDARDS
Safety
EN/IEC 62109-1/ UL 1741 / CSA C22.2 NO.107.1-16
1a) The solar charger will limit input power if more PV power is connected.
1b) The PV voltage must exceed Vbat + 5V for the controller to start. Thereafter the minimum PV voltage is Vbat + 1V.
2) A higher short circuit current may damage the solar charger in case of reverse polarity connection of the PV array.
3) Equalization is by default disabled.
4) For more information on data communication see the data communication paper in the Technical information section on our website.
9.2. Dimension drawings
9.2.1. Dimensions 100/35 and 150/45
BS-SS-MPPT-100-50-150-35-150-45.pdf
