MPPT solar charger manual
2. Introduction
The Victron Energy SmartSolar charge controller is an ultra fast Maximum Power Point Tracking (MPPT) solar charger with an outstanding conversion efficiency and is suitable for a wide range of battery and PV voltages.
2.1. Battery voltage, PV voltage and current rating
The solar charger can charge a lower nominal-voltage battery from a higher nominal voltage PV array. The controller will automatically adjust to the battery voltage and will charge the battery with a current up to its rated current.
The product name of the solar charger incorporates the maximum PV voltage and the maximum battery charge current.
For example: A 150/70 model has a maximum PV voltage of 150V and can charge the battery with a maximum of 70A.
The table below indicates the maximum PV voltage and maximum battery charge current of the solar chargers that are covered by this manual:
Solar charger model
Maximum PV voltage
Maximum battery charge current
Suitable battery voltages
MPPT 150/60
150V
60A
12, 24, 36 and 48V
MPPT 150/70
150V
70A
12, 24, 36 and 48V
MPPT 250/60
250V
60A
12, 24, 36 and 48V
MPPT 250/70
250V
70A
12, 24, 36 and 48V
2.2. TR or MC4 model
The solar charger is available in two different models, namely:
  • The TR version - The PV terminals are screw terminals
  • The MC4 version - The PV terminals are MC4 terminals
The 60A MC4 model has 2 MC4 male and female connector pairs.
The 70A MC4 model has 2 MC4 male and female connector pairs.
MPPT_TR_and_MC4.svg
From left to right: Example of solar chargers with screw terminals and MC4 PV connections
