11. Technical data
11.1. Technical data
SmartShunt IP65 | 500A |
Supply voltage range | 6.5 - 70 Vdc |
Current draw | < 1mA |
Input voltage range, auxiliary battery | 6.5 - 70 Vdc |
Battery capacity (Ah) | 1 - 9999 Ah |
Operating temperature range | -40 +50°C (-40 - 120°F) |
Auxiliary input | Measures voltage of second battery, temperature* or midpoint |
Temperature measurement range* | -20 +50°C |
VE.Direct communication port | Yes |
RESOLUTION & ACCURACY | |
Current | ± 0.01A |
Voltage | ± 0.01V |
Amp hours | ± 0.1Ah |
State of charge (0 - 100%) | ± 0.1% |
Time-to-go | ± 1 min |
Temperature (0 - 50°C or 30 - 120°F)* | ± 1°C/°F |
Accuracy of current measurement | ± 0.4% |
Offset | Less than 10 / 20 / 40 mA |
Accuracy of voltage measurement | ± 0.3% |
INSTALLATION & DIMENSIONS | |
Dimensions (h x w x d) | 500A: 46 x 120 x 54 mm 1000A: 68 x 168 x 75 mm 2000A: 68 x 168 x 100 mm |
Shunt connection bolts | M10 (0.3937 inch) |
Protection category | IP65 (potted) |
STANDARDS | |
Safety | EN 60335-1 |
Emission / Immunity | EN-IEC 61000-6-1 / EN-IEC 61000-6-2 / EN-IEC 61000-6-3 |
Automotive | EN 50498 |
Vbatt cable | 1.5m red cable, with 1A slow blow fuse and M10 eye terminal |
Aux cable | 1.5m red cable, with 1A slow blow fuse and M10 eye terminal |
VE.Direct cable ** | 1.5 black cable, with VE.Direct socket |
Temperature sensor | Optional (ASS000100000) |
A note regarding the range of the Bluetooth signal | The shunt and the electric cables do negatively influence the range of the Bluetooth signal. The resulting range of 10-15 meter is however satisfactory in most cases. The proximity of other electrically conducting elements, such as the metal chassis of a vehicle or seawater around the hull of a boat, may reduce the range of the Bluetooth signal to an unacceptable level. The solution in such a case is to add a VE.Direct Bluetooth Dongle (ASS030536011) to the system, and to switch off Bluetooth in the SmartShunt. |
* Only when optional temperature sensor is connected, temperature sensor is not included
** The very first production batch (50 pcs) has a 30 cm VE.Direct cable.
