The VE Transfer Switch is designed to take over automatic switching between different power sources. For example, between a generator and the shore, between an inverter and a generator, or between an inverter and the shore.
It has two inputs and one output and automatically transfers the available AC power from one of the inputs to the output. It can be used with any Victron Energy inverter, providing the inverter power rating does not exceed the transfer switch power rating.
The transfer switch can also be used to allow a MultiPlus inverter/charger to connect to two different AC sources, like shore power and a generator, instead of only being able to connect to a single AC source.
