VE Transfer Switch
4. Technical specifications
VE Transfer Switch
5kVA (COS 0)
10kVA (COS 0)
Nominal voltage
200 - 250Vac, single-phase
Nominal frequency
50 – 60Hz
Nominal current input 1
20A
40A
Nominal current input 2
20A
40A
Nominal output current
20A
40A
Maximum electromotor (air-conditioner) power
1.3kW
8kW
Power consumption input 1
6VA
6VA
Power consumption input 2
0VA
0VA
Transfer time by closing contacts
10 - 20ms
10 - 20ms
Transfer time by opening contacts
5 - 20ms
5 - 20ms
Contacts delay input 1
Approximately 10s (adjustable)
Auxiliary contact
200 - 240Vac, 20A, cos phi = 1
GENERAL
Operating temperature
-5°C to + 60°C
Maximum humidity (non-condensing)
95%
Miniature circuit breaker (MCB)
Not included - installation dependent
Earth leakage breakers (RCD)
ENCLOSURE
Protection category
IP 54
Colour
RAL 7035
Dimensions (mm)
175 x 215 x 120
175 x 215 x 120
Weight (kg)
1.85
1.65
