BatteryProtect 48V 100A
5. Technical specifications
5.1. Technical specifications
BatteryProtect
BP 48V 100A
Max. continuous load current
100A
Peak current
250A
Operating voltage range
32 - 60 V
Current consumption
When on: 2mA When off or low voltage shutdown: 1.5mA
Alarm output delay
12 seconds
Max. load on alarm output
50mA - short circuit proof
Load disconnect delay
90 seconds (immidiate if triggered by a BMS)
Load reconnect delay
30 seconds
Default thresholds
Disengage: 42 V Engage: 48 V
Operating temperature range
Full load: -40 °C to +40 °C (up to 60% of nominal load at 50 °C)
Connection
M8
Mounting Torque
9 Nm
Weight
0.8 kg 1.8 lbs
Dimensions (hxwxd)
62 x 123 x 120 mm
2.5 x 4.9 x 4.8 inch
