The Digital Multi Control 200/200A enables remote monitoring and control of inverter/charger systems in stand-alone, parallel, and 2- or 3-phase configurations. It seamlessly integrates with the helm, dashboard or control panel of your vessel, vehicle, or home system.
Notice
Note: "System" refers to interconnected inverter/chargers through RJ45 UTP cables.
MultiCompact.
MultiPlus, MultiPlus-II and MultiPlus-II GX.
Quattro and Quattro-II.
EasySolar and EasySolar-II GX.
Legacy (pre-VE.Bus) Multi, MultiCompact, MultiPlus and Quattro (2008 and earlier).
Installing the Digital Multi Control panel is straightforward. Simply connect the control panel to the inverter/charger system using an RJ45 UTP Cable. In most cases, no further setup is needed.
For expedited installation instructions, find your system type in the list below and click the appropriate link:
For comprehensive details about the control panel, including features, configuration, and operational information, consult the complete manual.
Digital Multi Control 200/200A.
Four mounting screws.
