Manual - EV Charging Station NS
1. Safety Instructions
Please read the safety instructions below before using the EV Charging Station NS to avoid risks of fire, electric shocks, personal injuries or equipment damage.
Installation and adjustments must be made by qualified personnel only. To reduce the risk of electric shock, do not perform any servicing other than that specified in the operating instructions unless you are qualified to do so.
For electrical work, follow the local national wiring standard, regulation and these installation instructions. Connection to the mains supply must be in accordance with the national regulations for electrical installations.
This product is designed and tested in accordance with international standards. The equipment should be used for its designated application only and in accordance with the specified operating parameters.
Warnings and cautions:
Caution
  • Never install near fire sources, explosive materials, combustibles or other flammable sources. Never use it at places where gas or other chemical explosions could occur.
  • It must be connected all the times to the ground, otherwise it will not allow charging.
  • Turn off the EV Charging Station NS power before installing or performing operations to it.
  • Make sure children are supervised if using the equipment.
  • Do not put fingers or insert objects or sharp metallic objects into the terminals. Do not insert objects into any other parts of the EV Charging Station NS.
  • Do not use the device if the power cord or EV cable is broken, shows any signs of damage or does not function properly.
  • Do not use the EV Charging Station NS if it is broken, defective, cracked, damaged or does not function properly.
  • Do not apply strong force on the equipment, to prevent crashes and deterioration.
  • Do not use any sharp objects to damage the product.
  • Do not service the equipment by yourself, do not open, disassemble or make any modifications to it. Contact your Victron Energy Distributor.
  • Do not touch any live electrical parts.
  • Do not place the EV cables connected to the charging station in water.
  • Make sure ground connection is properly done to prevent equipment damage.
  • Transport the device with care in its original package to avoid damage to it and its components.
  • Store in a dry environment, at temperatures between –20 °C to 60 °C.
  • Do not operate at temperatures outside the operating range of -25 ˚C to 50 ˚C.
  • As the EV Charging Station NS can affect the functioning of certain medical electronic implants, check any potential side effects with your electronic device manufacturer before using the device.
