GX GSM | GSM100100100 | GSM100200100 |
Supply voltage range | 8 - 70VDC |
Power draw | 2.5W while 2G/3G data transfer <1.0W in idle mode +0.4W if GPS is enabled |
Operating temperature range | -40 +50°C (-40 - 120°F) |
Power cable (included) | 1.4m cable with inline fuse holder, terminal block and 10mm ring terminals |
Inline fuse (included) | T3.15A250V |
COMMUNICATION | |
USB communication port | Fixed 1.0m cable with USB-A connector (connects to the GX device) |
LTE antenna connector | Type SMA Female (optional Outdoor 2G and 3G GSM antenna GSM900100100) |
GPS antenna connector | Type SMA Female (optional GPS antenna GSM900200100) |
GNSS | GPS/Beidou/GLONASS/GALILEO/QZSS |
SIM card | Regular Mini SIM (supports both 1.8V and 3V) |
Data transmission (max. Download/Upload) | 3G (HSPA+): 42 Mbps / 5.76 Mbps 2G (EDGE): 236.8 Kbps / 236.8 Kbps 2G (GPRS): 85.6 Kbps / 85.6 Kbps |
Status indicator | Blue LED |
INSTALLATION & DIMENSIONS | |
Dimensions (l x w x h) | 106 × 42.5 × 22mm |
Weight | 0.08kg (0.177lbs) |
Wire gauge (power cable) | 0.5..1.5mm2 / AWG 28..16 or use supplied power cable |
Recommended fuse size | 500mA @ 12V / 250mA @ 24V / 100mA @ 48V or use supplied inline fuse |
STANDARDS | |
Safety | EN 60335-1 / EN 60335-2-29 / EN 62368-1 |
Emission / Immunity | ECE R10-5 |
QM | EN 9001:2015 |
In this section:
