GX GSM manual
2. Features
In this section:
2.1. Built-in GPS receiver
The GX GSM includes a built-in GPS receiver. When the optional active GPS antenna is installed, the system can be tracked as well as geo-fenced on the VRM Portal.
The required accessory part number is GSM900200100 - Active GPS Antenna for GX GSM.
2.2. GX compatibility
The GX GSM can be used with any of the GX devices and requires Venus OS v2.22 or newer to be installed on the GX device.
2.3. SIM card
It requires a SIM card of the Mini-SIM format and connects to the GX device with an included 1m USB cable.
2.4. When to use a mobile router instead
Note
The GX GSM provides an internet connection for the GX device only. There is no option to share the internet to laptops, phones, or other devices.
For installations where more devices need internet, such as a yacht or RV, consider installing a mobile router instead.
2.5. Antennas and accessories
A small indoor GSM antenna is included. Optionally, we also sell an outdoor outdoor 2G and 3G GSM antenna, which increases the range:
  • Part number GSM900100100 - Outdoor 4G GSM Antenna
2.6. What's in the box?
  • GX GSM (with integrated USB cable)
  • GSM mini rod antenna (for indoor use)
  • DC power cable (with inline fuse and terminal block)
