Power | Lynx Smart BMS NG 500A | Lynx Smart BMS NG 1000A |
Supply voltage range | 9 – 60 Vdc | |
Supported system voltages | 12, 24 or 48 V | |
Reverse polarity protection | No | |
Main safety contactor continuous current rating | 500 A continuous | 1000 A continuous |
Main safety contactor peak current rating | 600 A for 5 minutes | 1200 A for 5 minutes |
Power consumption OFF mode | 0.3 mA for all system voltages | |
Power consumption in Standby mode | Approximately 0.6 W (50 mA at 12 V) | |
Power consumption in ON mode | Approximately 2.6 W (217 mA at 12 V), depending on the state of the relays | Approximately 4.2 W (350 mA at 12 V), depending on the state of the relays |
Minimum load resistance for pre-charging | 10 Ω and above for 12 V systems 20 Ω and above for 24 V and 48 V systems | |
AUX output maximum current rating | 1.1 A continuous, protected by a resettable fuse | |
Allow-to-charge port maximum current rating | 0.5 A at 60 Vdc, protected by a resettable fuse | |
Allow-to-discharge port maximum current rating | 0.5 A at 60 Vdc, protected by a resettable fuse | |
Programmable relay (SPDT) maximum current rating | 2 A at 60 Vdc |
Connections | Lynx Smart BMS NG 500A | Lynx Smart BMS NG 1000A |
Busbar and torque | M10 (Torque: 33 Nm) | |
VE.Can | RJ45 and RJ45 terminator | |
I/O | Removable 13-pin multi-connector with screw terminals | |
Battery BMS cables | Male and female circular 3-pole connector with M8 screw ring Up to 50 batteries can be connected to the BMS by daisy chaining them | |
Lynx Distributor (up to 4 modules) | RJ10 (cable ships with each Lynx Distributor) |
Physical | Lynx Smart BMS NG 500A | Lynx Smart BMS NG 1000A |
Enclosure material | ABS | |
Enclosure dimensions (h x w x d) | 190 x 180 x 80 mm | 230 x 180 x 100 mm |
Unit weight | 1.9 kg | 2.7 kg |
Busbar material | Tinned copper | |
Busbar dimensions (h x w) | 8 x 30 mm |
Environmental | Lynx Smart BMS NG 500A | Lynx Smart BMS NG 1000A |
Operating temperature range | -40 °C to +60 °C | |
Storage temperature range | -40 °C to +60 °C | |
Humidity | Max. 95 % (non-condensing) | |
Protection class | IP22 |
Standards | Lynx Smart BMS NG 500A | Lynx Smart BMS NG 1000A |
Safety | EN-IEC 63000:2018 | |
EMC | EN-IEC 61000-6-3:2007/A1:2011/AC:2012 | |
QMS | NEN-EN-ISO 9001:2015 |
