Three-phase connection
The MultiPlus can also be used in a 3-phase wye (Y) configuration. To this end, a connection between the devices is made by means of standard RJ45 UTP cables and RJ45-splittera splitter (the same as for parallel operation). The system (MultiPlus units plus an optional control panel) will require subsequent configuration, see the Configuration chapter. For the prerequisites see the previous Parallel connection chapter.
Note: The MultiPlus is not suitable for a 3-phase delta (Δ) configuration.
Three-phase connection diagram.
