Technical specifications
MultiPlus | 12/500/20 - 120V | 12/800/35 - 120V | 12/1200/50 - 120V | ||
PowerControl / PowerAssist | Yes / Yes | ||||
Transfer switch | 16A | ||||
INVERTER | |||||
DC Input voltage range | 9.5 - 17V | ||||
AC output voltage | 120V ±2% | ||||
AC output frequency | 60Hz ±0.1% | ||||
Cont. output power at 25°C (77°F) (2) | 500VA | 800VA | 1200VA | ||
Cont. output power at 25°C (77°F) | 430W | 700W | 1000W | ||
Cont. output power at 40°C (104°F) | 400W | 650W | 900W | ||
Cont. output power at 65°C (149°F) | 300W | 400W | 600W | ||
Peak power | 900W | 1600W | 2400W | ||
Maximum efficiency | 90% | 92% | 93% | ||
Zero-load power | 6W | 7W | 10W | ||
Zero-load power search mode | 2W | 2W | 3W | ||
CHARGER | |||||
AC Input voltage range | 95 - 140V | ||||
AC input frequency range | 55 - 65Hz | ||||
Charge voltage 'absorption' | 14.4V | ||||
Charge voltage 'float' | 13.8V | ||||
Charge voltage 'storage' | 13.2V | ||||
Charge current house battery (3) | 20A | 35A | 50A | ||
Charge current starter battery | 1A | ||||
Battery temperature sensor | Yes | ||||
GENERAL | |||||
Programmable relay (4) | Yes | ||||
Protection (1) | a – g | ||||
Operating temperature | -40 to +65°C (-40 to + 140°F), fan assisted cooling | ||||
Humidity | Maximum 95%, non-condensing | ||||
ENCLOSURE | |||||
Material & colour | Steel/ABS, blue RAL 5012 | ||||
Protection category | IP 21 | ||||
Battery-connection | 16mm² | 25mm² | 35mm² | ||
230V AC-connection | G-ST18i connector | ||||
Weight | 4.4kg | 6.4kg | 8.2kg | ||
Dimensions (h x w x d) | 311 x 182 x 100 mm | 360 x 240 x 100 | 406 x 250 x 100 mm | ||
STANDARDS | |||||
Safety | EN-IEC 60335-1, EN-IEC 60335-2-29, EN 62109-1 | ||||
Emission / Immunity | EN 55014-1, EN 55014-2, EN-IEC 61000-3-2, EN-IEC 61000-3-3 IEC 61000-6-1, IEC 61000-6-2, IEC 61000-6-3 | ||||
Road vehicles | ECE R10-4 | ||||
