The VE Panel provides you with circuit breakers/disconnects to easily operate and maintain your inverter/battery system.
These breakers are used as the main power disconnecting means and/or overcurrent protection.
![]() | INFO: For information on operating the inverter/charger, refer to its owner’s manual. |
If a short-circuit condition occurs, or if a load is placed on the circuit breaker that is more than its rated capacity, the breaker will trip OFF.
Before resetting the breaker, first determine the cause of the overcurrent fault. Then, reset the circuit breaker by turning it all the way OFF, and then all the way back ON. For proper maintenance and longer life, the circuit breakers should be turned off and on several times at least once a year. This will help to prevent the contacts inside from sticking together.
![]() | INFO: Operating temperature range for the MultiPlus and Quattro inverter/charger: -40 to +65°C / -40 to 150°F (fan assisted cooling) Humidity (non-condensing): max 95% |
![]() | WARNING: To shut the VE Panel-inverter/charger system OFF completely, all of the circuit breakers in VE Panel should be switched to the OFF position. |
