The Lynx Shunt VE.Can (M10) is an integral part of the Lynx Distribution system, featuring a positive and negative busbar, a battery monitor, and a fuse holder for the main system fuse. It is available in two versions: M8 and M10. The shunt can communicate with GX devices via VE.Can. Additionally, it is equipped with a power LED for status indication.
The Lynx Shunt VE.Can(M10) - with and without cover
The Lynx Shunt VE.Can (M8) - with and without cover
The M10 model includes an additional piece of busbar that can replace the fuse inside the shunt, providing the flexibility to place the main fuse outside the shunt in a different location. This is particularly useful in larger systems where higher-rated fuses are required.
Two VE.Can RJ45 terminators are included, which are used when connecting to a GX device.
Two VE.Can RJ45 VE terminators
The Lynx Shunt VE.Can M8 is designed to hold a CNN fuse, while the M10 model can also accommodate an ANL or Mega fuse. The fuses need to be purchased separately. For more info see Fusing
Examples of a CNN, ANL and Mega fuse
Lynx Shunt VE.Can (M10) | ||
VE.Can RJ45 terminators (2 pcs) | ||
Temperature sensor (ASS000001000) with ferrules and terminal block |
Fuse dummy (piece of busbar) |
Upside-down sticker with quick installation guide |
Folder with product labels |
The Lynx Shunt VE.Can (M10) can be monitored and set up with a GX device.
For more information on the GX device, see the GX device product page.
The GX device can be connected to the VRM portal, allowing remote monitoring.
For more information on the VRM portal, see the VRM page.
GX devices: Cerbo GX & GX Touch, CCGX and Venus GX
A temperature sensor can be connected to the Lynx Shunt VE.Can (M10). It is used to measure the battery temperature.
The temperature sensor is included with the Lynx Shunt VE.Can (M10). For more information see the Temperature sensor QUA PMP GX device product page.
The temperature sensor QUA PMP GX device
The Lynx Distribution System is a modular busbar system that incorporates DC connections, distribution, fusing, battery monitoring and/or Lithium battery management. For more information, see the DC Distribution Systems product page.
The Lynx Distribution System consist of the following parts:
Lynx Power In - A positive and negative busbar with four batteries or DC equipment connections, available in two versions, with M8 or M10 busbar.
Lynx Class-T Power In - A positive and negative busbar that accepts two Class-T fuses and has two battery or DC equipment connections, available with M10 busbar.
Lynx Distributor - A positive and negative busbar with four fused connections for batteries or DC equipment and fuse monitoring, available in two versions, with M8 or M10 busbar.
Lynx Shunt VE.Can - A positive busbar with a space for a main system fuse and a negative busbar with a shunt for battery monitoring. It has VE.Can communication for monitoring and setup with a GX device. Available in two versions, with M8 or M10 busbar.
Lynx Smart BMS - For use together with Victron Energy Smart Lithium batteries. It contains a positive busbar with a contactor driven by a battery management system (BMS) and a negative busbar with a shunt for battery monitoring. It has Bluetooth communication for monitoring and setup via the VictronConnect App and VE.Can communication for monitoring with a GX device and the VRM portal. Available as a 500A model with M8 or M10 busbars or 1000A model with M10 busbars.
The Lynx modules: Lynx Power In, Lynx Class-T Power In, Lynx Distributor, Lynx Shunt VE.Can and Lynx Smart BMS
