Power | |
Supply voltage range | 9 - 70 Vdc |
Supported system voltages | 12, 24 or 48 V |
Reverse polarity protection | No |
Current rating | 1000 Adc continuous |
Power consumption | 60 mA @ 12 V 33 mA @ 24 V 20 mA @ 48 V |
Potential free alarm contact | 3 A, 30 Vdc, 250 Vac |
Connections | |
Busbar | M10 |
Fuse or fuse dummy | M8 (a Mega fuse can be installed on the M6 bolts) |
VE.Can | RJ45 and RJ45 terminator |
Power supply connection to Lynx Distributor | RJ10 (a RJ10 cable ships with each Lynx Distributor) |
Temperature sensor | Terminal connector (Sensor included) |
Relay | Screw terminal |
Physical | |
Enclosure material | ABS |
Enclosure dimensions (hxwxd) | 190 x 180 x 80mm |
Unit weight | 1.4 kg |
Busbar material | Tinned copper |
Busbar dimensions (hxw) | 8 x 30mm |
Environmental | |
Operating temperature range | -40 °C to +60 °C |
Storage temperature range | -40 °C to +60 °C |
Humidity | Max. 95 % (non-condensing) |
Protection class | IP22 |
