Important
SAVE THESE INSTRUCTIONS – This manual contains important instructions that shall be followed during installation and maintenance.
Caution
Danger of explosion from sparking and danger of electric shock
General
Please read the safety instructions below before installing and using the Orion XS to avoid risks of fire, electric shocks, personal injuries or equipment damage.
This product is designed and tested in accordance with international standards. The equipment should be used for its designated application only and in accordance with the specified operating parameters.
Installation
For electrical work, follow the local national wiring standards, regulations and these installation instructions.
Install the product in a heatproof environment. Ensure therefore that there are no chemicals, plastic parts, curtains or other textiles, etc. in the immediate vicinity of the equipment.
It is normal for the Orion XS to get hot during operation. Keep any objects that are heat-sensitive away.
Never install or use the product at sites where gas or dust explosions could occur.
Use flexible multi-stranded copper cables for the connections (UL: Class I; IEC: Class 5).
The installation must include a fuse in accordance with the recommendations in the table Cable type recommendations.
Operation, service and maintenance
Ensure that the equipment is used under proper operating conditions.
This device is not to be used by persons (including children) with reduced physical, sensory or mental capabilities or lack of experience and knowledge unless they have been given supervision or instruction.
Always provide proper ventilation during charging.
Avoid covering the Orion XS 12/12-50A DC-DC battery charger.
Never place the battery charger on top of the battery during charging.
Prevent sparks close to the battery. A battery being charged could emit explosive gasses.
Refer to the battery manufacturer's specifications to ensure that the battery is suitable for use with this product. The safety instructions of the battery manufacturer must always be observed.
In addition to this manual, the system operation or service manual must include a battery maintenance manual applicable to the type of batteries used.
Do not use the device if it shows any signs of damage or does not function properly.
Do not use the Orion XS 12/12-50A DC-DC battery charger if it is broken, defective, cracked, damaged, or malfunctioning.
The Orion XS 12/12-50A DC-DC battery charger contains no serviceable parts.
Regular maintenance of the Orion XS 12/12-50A DC-DC battery charger is not required.
Avoid moisture, oil/soot/vapours, and keep the device clean.
Clean the front side of the Orion XS 12/12-50A DC-DC battery charger using a dry cloth.
