VRM Portal manual
12. Event Logs
Certain data is logged in the VRM Portal, which can be viewed later to be included in troubleshooting a system.
  • Alarm logs
    • See which device triggered an alarm, the type of alarm, when the alarm started and when it was cleared.
  • Event logs
    • The event log contains data that you can use to view specific changes to the installation down to the minute, for example, firmware updates, which controls were activated or deactivated by whom, ESS status changes, who accessed the Remote Console, tag changes, user permission changes, etc.
Note this log data cannot be modified. If you wish to clear log data you will need to delete the installation (including all other history data), reboot the GX device, and start again.
