VRM Portal manual
16. VRM error codes
This section provides a comprehensive list of VRM error codes, their causes, and potential resolutions.
Table 1. VRM error codes
Code
API HTTP
Error message key
Error message text (EN)
1429 - Rate limited
429
core.rate_limiting_error
You've sent too many requests. Please try again in a few minutes.
1403 - Forbidden
403
Backend string
You don't have sufficient rights to perform this action.
1422 - Validation error
422
Backend string
{validation_error_from_API}
1500 - Internal Server Error without Status
500
core.backend_unavailable
The server back-end is not available right now, please try again in a few minutes.
1510 - Internal Server Error with Status
500
Variable: error.statusText
1511 - error_with_data_message
200
Variable: error.data.message
Something went wrong, please try again later.
1520 - unknown_error
504
core.unknown_error
Unknown error, please try again in a few minutes.
1504 - Gateway timeout
core.request_timed_out
One of the requests timed out. Some elements might not load correctly. Please try again later.
RTT > 200
general.installation_overloaded_disabling_mqtt
Realtime connection disabled due to GX device overload.
