Manual - EV Charging Station
2. Description and features
2.1. Description
The EV Charging Station with its three-phase and single-phase charging capabilities integrates seamlessly into the Victron environment with its GX device connection via WiFi and enables easy operation and control via Bluetooth and the VictronConnect App. It delivers a maximum of 22kW AC in three-phase or 7.3kW in single-phase mode. A built-in 4.3-inch LCD touch screen enables easy monitoring and control.
Not only does this EV charging station fully integrate with a Victron Energy GX device and VRM, if you have solar, it can also be set up to allow excess energy from the sun to directly charge your vehicle once certain parameters are met. See the Setup, configuration & operation chapter for details.
The tough plastic enclosure is designed to withstand harsh weather and can be mounted inside or outside.
A programmable RGB light ring around the charging port (type 2 EV charging plug) allows for quick determination of the device state and can be programmed from the integrated web interface to display different light effects based on the current state (disconnected, charging, charged etc.).
2.2. Features
2.3. What's in the box?
  • EV Charging Station with supplied 28mm nylon cable gland for power cables up to 19mm in diameter
