GlobalLink 520
1.5m power cable with 1A inline fuse, M10 eyelets and power connector
2 pluggable terminal blocks with spring clamps
What's not in the box
VE.Direct cables
Make a note of the VRM Portal ID indicated on the sticker on the GlobalLink 520 .
Mount the GlobalLink 520 close to the device you wish to monitor.
Connect your compatible devices to the GlobalLink 520 via a VE.Direct cable (available in different lenghts) or via Bluetooth (see chapter Victron smart devices and RuuviTags).
Connect the DC Power (8V - 70V).
The LED will start blinking blue while trying to connect to the network (this can take up to 5 minutes).
The LED will blink green and yellow when one VE.Direct device is connected, or green only when two VE.Direct devices are connected.
Visit the VRM portal to 'add' your installation to your account using the Portal ID you wrote down in step 1. You can only add your device to VRM once it has connected to the network (blinking yellow and/or green).
