Isolation Transformer | 2000 Watt | 3600 Watt |
AC input voltage * | 115 or 230V | 115 or 230V |
AC output voltage * | 120 or 240V | 120 or 240V |
Frequency | 50/60Hz | 50/60Hz |
Output current rating | 19A (115V) 8.5A (230V) | 32A (115V) 16A (230V) |
Soft start | Yes | |
Operating temperature range | -20°C to 40°C | |
Humidity | Max 95%, non-condensing | |
Transformer type | Toroidal (low noise, low weight), 1:1.05 ratio | |
Enclosure | Aluminium (blue RAL 5012) | |
Protection category | IP21 | |
Safety | EN 60076 | |
Weight | 12.7kg | 23kg |
Dimensions (h x w x d), mm | 375 x 214 x 135 | 362 x 258 x 218 |
*) The isolation transformer can be used as:
115V to 120V isolation transformer
230V to 240V isolation transformer
115V to 240V isolation transformer
230V to 120V isolation transformer
