MPPT solar charger manual
9. Technical specifications
9.1. Specifications 75/10, 75/15, 100/15 and 100/20
MPPT 75/10
MPPT 75/15
MPPT 100/15
MPPT 100/20
Battery voltage (auto select)
12V or 24V
12V, 24V, or 48V
Maximum battery current
10A
15A
15A
20A
Nominal PV power, 12V 1a,b
145W
220W
220 W
290W
Nominal PV power, 24V 1a,b
290W
440W
440 W
580W
Nominal PV power, 48V 1a,b
1160W
Max. PV short circuit current 2
10A
15A
15A
20A
Automatic load disconnect
Yes
Maximum PV open circuit voltage
75V
100V
Peak efficiency
98%
Self consumption
12V: 20mA / 24V: 10mA
12V: 25mA
24V / 48V: 15mA
Charge voltage 'absorption'
14.4V / 28.8V / 57.6V (adjustable)
Charge voltage 'float'
13.8V / 27.6V / 55.2V (adjustable)
Charge voltage 'equalization' 3
16.2V / 32.4V / 64.8V (adjustable)
Charge algorithm
Multi-stage adaptive or user defined algorithm
Temperature compensation
12V: -16mV/°C / 24V: -32mV/°C / 48V: -64 mV/°C
Continuous load current
15A
12V & 24V: 20A
48V: 1A
Low voltage load disconnect
11.1V / 22.2V / 44.4V or 11.8V / 23.6V / 47.2V or BatteryLife algorithm
Low voltage load reconnect
13.1V / 26.2V / 52.4V or 14V / 28V / 56V or BatteryLife algorithm
Protection
PV reverse polarity, output short circuit, over temperature
Operating temperature
-30°C to +60°C (full rated output up to 40°C)
Humidity
100%, non-condensing
Maximum altitude
5000m (full rated output up to 2000m)
Environmental condition
Indoor type 1, unconditioned
Pollution degree
PD3
Data communication
VE.Direct port 4
Bluetooth, via the VictronConnect app
ENCLOSURE
Colour
Blue (RAL 5012)
Power terminals
6mm² / AWG10
Protection category
IP43 (electronic components), IP22 (connection area)
Weight
0.5kg
0.6kg
0.65kg
Dimensions (h x w x d)
100 x 113 x 40mm
100 x 113 x 50mm
100 x 131 x 60mm
STANDARDS
Safety
EN/IEC 62109-1 / UL 1741 / CSA C22.2 NO.107.1-16
1a) The solar charger will limit input power if more PV power is connected.
1b) The PV voltage must exceed Vbat + 5V for the controller to start. Thereafter the minimum PV voltage is Vbat + 1V.
2) A higher short circuit current may damage the solar charger in case of reverse polarity connection of the PV array.
3) Equalization is by default disabled.
4) For more information on data communication see the data communication paper in the Technical information section on our website.
9.2. Dimension drawings
9.2.1. Dimensions 75/10 and 75/15
Blue-Smart-Solar-charge-controller-MPPT-75V-10A-15A-Dimensions.pdf
9.2.2. Dimensions 100/15
BlueSolar-_-Smartsolar-MPPT-100-15.pdf
9.2.3. Dimensions 100/20
Dimensions-SmartSolar-MPPT-100V-20A.PDF
